Data doctor's
aminhas
Data doctor's
Hello:
any buddy give me tutorial of all data doctor's tools how to used?
4 REPLIES 4
If you search for IDD in the help files, you get a pretty good breakdown of what is available.
If you have the LearningConnector, you get a really nice list.
  • To Delete Geometry in IDD
  • About Curves in IDD
  • About Converting Surfaces in IDD
  • About the Cut Operation in IDD
  • About the Copy Operation in IDD
  • About Delete Operation in IDD
  • About the IDD Transform Tool
  • About UV-Curves in IDD
  • About the Paste Operation in IDD
  • About Paste Special Operation in IDD
  • To Cut, Copy, and Paste Special in IDD
  • To Cut, Copy, and Paste Geometry in IDD
  • About Sections for Surface Conversion in IDD
  • To Transform Geometry in IDD Using Adjust
  • About Datum Entity Creation in IDD
  • About Editing Surface Boundaries in IDD
  • To Convert Surfaces in IDD and Modify Them
  • About Orientation Reference for Surface Conversion in IDD
  • About Origin Manipulation for Surface Conversion in IDD
  • About Compute Option for Surface Conversion in IDD
  • To Transform Geometry in IDD Using Placement Constraints
  • To Transform Geometry in IDD Using Orient Mode
  • To Transform Geometry in IDD Using Translate or Rotate
  • About the IDD Surface Conversion User Interface
You can also try the learning exchange if you have maintenance...
http://learningexchange.ptc.com/tutorials/search?product_id=1&search=import+data+doctor
Hi Adnan,
Here is an article that contains some useful information on this tool.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS53903
aminhas
(To:ClintWalton)
can't asscess
Hello Adnan,
Our apologies for providing a solution that is inaccessible. We did not intend to to set you on such a path.
Unfortunately, accessing the PTC Knowledge Base requires current Support Maintenance. I notice from your profile that you do not currently have Maintenance.
If you do have current Support Maintenance, please contact Global Support at 1-800-477-6435, then 9, then 2.
Kael Lizak
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
