ThingWorx Mashups Professional Certification Exam 2024
Abhishek_Tirkey
7-Bedrock
1. What types of question is been asked? like MCQ, Practical ?
2. Total Numbers of Questions?
3. How will be the Difficulty Level - Easy, Medium, Hard?
4. Can Beginner easily able to crack the exam?
5. Some suggestions or advice for scoring good marks in the exams.
Abhishek Tirkey
Abishek,
1) All questions are multiple choice. However, you are given a ThingWorx environment, and you must use it to get the correct answer to some of the questions.
2) There are 23 questions on the exam. If you take it more than once, you will not get the same set of questions.
3-4) This is a very difficult exam. I would say a beginner is unlikely to pass, and passing may require some real-world implementation experience.
If you take this exam, I suggest not worrying too much about time. 23 multiple questions in 3 hours is very comfortable from a timing standpoint.
Although it's tough, it is open-note and timing is comfortable, so if you take it, consider keeping the ThingWorx Help Center and references to the source PTCUniversity courses available to you during the exam. You have some time to try and look stuff up during the exam.
Hi @Abhishek_Tirkey   1. MCQ question
2. not remember but it takes 3 hours.
3. Mostly hard and medium questions
4. Chance is less
5. You need to learn the below topics.
Summarize ThingWorx UI Framework
• Describe ThingWorx Mashups
• Create Mashups with Mashup Builder
• Create Style Definitions
• Discuss UI/UX Principles
• Manage Mashup Builder Canvas
Abishek,
Thank you @AdamM.Levine
What would be the Prerequisite for this exam - ThingWorx Associate Certification Exam 2024
Abhishek Tirkey
This should provide answer to your query.
regards
~Syed
