I just purchased a subscription to Creo Parametric.
How do I use the LMS eLearning that comes with it?
Thanks.
You (or someone in your org) should have received an email about this.
Maybe this document will help clarify. https://www.ptc.com/-/media/Files/PDFs/Services/J13654_Renewals-Toolkit_eLearning_EN.pdf
@JeffFilo Can you help?
Bettina
Bettina
I did get eLearning figured out. The best help came from Hedy. Thank you and KUDO's. I am now learning Creo Parametric 7.0.2.0.
