Am I making a tessellated sphere correctly in Creo
Newbie
I need to make a model of a sphere with a sensor screwed into every vertex of a tessilated sphere. My plan at the moment is to calculate those vertices in an external program, import the points into creo, then use the patern tool selecting each datum point. Is there an easier way to do this?
Tags (2)
12 REPLIES 12
Re: Am I making a tessellated sphere correctly in Creo
That's how I'd do it.
You could do it entirely in Creo, but it wouldn't be easier or faster. The advantage would be that you could easily change the number of facets afterwards but you have to weigh up if the initial time investment would pay off for the number of times you're likely to change it.
Antonius' information is probably a really good place to start.
But I have to ask how many sensors? 4 or 400, might change the thought process.
40000
I don't think Antonius' method would work. Maybe this is something creo just can't do.
I have the points in creo, but when I pattern them, they point in the same direction as the first hole.
There so many sensors for this to work.
Yeah, see, that is some key information right there. And how big is the sphere going to be?
There is an option in the fill pattern that used the surface normals. Unfortunately, for a point pattern, points have this information built into them. I have had this issue before where we do not have good control of how the points are defined internally. I've had similar shortcomings with splines where you expected the normal to "twist" but didn't depending solely on how they were generated.
I maybe giving too much information on the product. Bigger then a workout ball, let's say. Fairly big.
Highlighted
Fill patterns, hmmm, let me look those up. I'll get back to you.
