Can you create a drop down list for parameters in Creo?
AndyHermanson
I am looking to see if there is a way to create drop down lists for user created parameters.
Example: If you assign multiple material files to a part in Creo you then get a drop down list of those material files.
I want to be able to do this with user/Admin create parameters. Anyone have any ideas?
Thanks in advance.
Andy
31 REPLIES 31
Martin, thanks a lot.
I am working on implementing this for our material callouts and have it working with the exception of within family tables.
With the generic I can select one of the materials from the table I built following this
Table-Restricted Parameters
However when I make a family table the only option available is the one from the generic. Is there a way to have all of  the materials in my table available for the instances?
I am replying back to this thread because it is far more recent than the other one specifically for using tables.
Edit
I can get the parameter matl to the family table, however the parameter material the is driven in the table will not update. If I open the instances they show the correct material. If I write a relation of material_callout=material it updates correctly. What is going wrong. I have attached my parameter file and a screen show of the family table.
