Creo 3.0 M30 Feature Mirror
scampbell
6-Contributor
What is up with the mirror command. I am finding lots of failures when making a dependant feature mirror.. It simply won't update the other side when I change even teh depth of the diring feature!!  On top of that it won't updated remove / add material when updated!
Is there a fix coming anytime soon??
Steve Campbell
Have you checked the options...
Available options are limited.
scampbell
6-Contributor
(To:jhaston-2)
I did and i had the same options checked. I'm going to make sure that we are on the m50 release
scampbell
6-Contributor
(To:scampbell)
we are on m30
Yes, I should have mentioned I'm just using Creo 2.0 (M140).
I had a case logged with PTC some time ago.
The outcome was that the mirror feature works as intended (providing only limited function).
Selecting the "Fully dependent..." option only gives some additional control, if I remember correctly.
See also... PTC case C12270066
