I have created a slot on the end of the part.
When making the detail drawing a line shows up across the slot that makes it look as if the slot is only partially throught the part.
Has anyone seen this and found a soltion?
Unit accuracy is set to .0001
Wildfire 4.0 M220
Shiva,
Thanks for the assist. Changing the order in the model tree solved my problem.
