Equations for Curves (and more)
- 21 replies
- 76798 views
- Translate All
I wish I had found a list like this a few years ago. I've searched the web and compiled the following list for your enjoyment. Many are probably considered basic with a few very cool, complex curves thrown in. The list is divided into the coordinate systems that you will have to choose when creating the datum curve.
To initiate the command that will allow you to try these, go to Insert>Model Datum>Curve>From Equation.
After the Equations section see the section title Links to find PlanetPTC discussions and videos that have demonstrated and, in some cases, explained the curve from equation command in more detail with ways to incorporate relations and parameters.
Attached is a Creo Elements/Pro 5.0 part file with all of the equations included.
In the comments, please share any equations or links that you know. Other suggestions are welcome, too.
EQUATIONS
Cartesian Coordinates: x, y, & z
The z variable is not necessary, but when used will give the curve that extra dimension. If in doubt, try z = t*10.
Sine
Cartesian coordinates
x = 50 * t
y = 10 * sin (t * 360)
Rhodonea
theta = t * 360 * 4
x = 25 + (10-6) * cos (theta) +10 * cos ((10/6-1) * theta)
y = 25 + (10-6) * sin (theta) - 6 * sin ((10/6-1) * theta)
Involute
r = 1
ang = 360 * t
s = 2 * pi * r * t
x0 = s * cos (ang)
y0 = s * sin (ang)
x = x0 + s * sin (ang)
y = y0-s * cos (ang)
Logarithmic
z = 0
x = 10 * t
y = log (10 * t +0.0001)
Double Arc Epicycloid
l = 2.5
b = 2.5
x = 3 * b * cos (t * 360) + l * cos (3 * t * 360)
Y = 3 * b * sin (t * 360) + l * sin (3 * t * 360)
Star Southbound
a = 5
x = a * (cos (t * 360)) ^ 3
y = a * (sin (t * 360)) ^ 3
Leaf
a = 10
x = 3 * a * t / (1 + (t ^ 3))
y = 3 * a * (t ^ 2) / (1 + (t ^ 3))
Helix
x = 4 * cos (t * (5 * 360))
y = 4 * sin (t * (5 * 360))
z = 10 * t
Parabolic
x = (4 * t)
y = (3 * t) + (5 * t ^ 2)
z = 0
Eliptical Helix
X = 4 * cos (t * 3 * 360)
y = 2 * sin (t * 3 * 360)
z = 5
Disc Spiral 1
/* Inner Diameter
d = 10
/* Pitch
p = 5
/* Revolutions
r = 5
/* Height; use 0 for a 2D curve
h = 0
x = ((d/2 + p * r * t) * cos ((r * t) * 360))
y = ((d / 2 + p * r * t) * sin ((r * t) * 360))
z = t * h
Butterfly
a=cos(t*360)
b=sin(t*360)
c=cos(4*t*360)
d=(sin((1/12)*t*360))^5
x=b*(exp(a)-2*c+d)
y=a*(exp(a)-2*c+d)
Fish
a = cos (t * 360)
b = sin (t * 360)
/* As "c" increases the fish gets fatter until it transforms into a figure 8.
c = 10
x = (C*a-20*((b)^2)/1.5)
y = c * a * b
Cappa
/* "c" is a scaling variable
c=20
/* Revolutions
r=1
/* Height
h=0
x=c*cos(t*r*360)*sin(t*r*360)
y=c*cos(t*r*360)
z=t*h
Star
/* "a" & "b" are scaling variables
a=2
b=2
/* If, r=2/3 ----> astroid
/* If, r=2 ----> ellipse; when a=b, its a circle
/* r cannot equal 1
r=2/3
x=a*(cos(t*360))^(2/r)
y=b*(sin(t*360))^(2/r)
z=0
Bicorn
/* "c" is a scaling variable.
c=5
a=cos(t*360)
b=sin(t*360)
x=c*a
y=c*(a^2)*(2+a)/(3+b^2)
Talbots
c=10
a=cos(t*360)
b=sin(t*360)
x=C*a*(1+exp(2)*(b^2))
y=C*b*(1+exp(2)*(b^2))
Cylindrical Coordinates: r, theta, & z
Spiral
Cylindrical coordinates
r = t
theta = 10 + t * (20 * 360)
z = t * 3
Circle Spiral Column
theta = t * 360
r = 10 +10 * sin (6 * theta)
z = 2 * sin (6 * theta)
Helical Wave
r = 5
theta = t * 3600
z = (sin (3.5 * theta-90)) +24 * t
Basket
r = 5 + 0.3 * sin (t * 180) + t
theta = t * 360 * 30
z = t * 5
Disc Spiral 2
R = 50 + t * (120)
Theta = t * 360 * 5
Z = 0
Apple
a = 10
r = a * (1 + cos (theta))
theta = t * 360
Spherical Coordinates: rho, theta, & phi
Butterfly Ball
Spherical coordinates
rho = 8 * t
theta = 360 * t * 4
phi = -360 * t * 8
Spherical Helix
rho = 4
theta = t * 180
phi = t * 360 * 20
UFO
rho = 20 * t ^ 2
theta = 60 * log (30) * t
phi = 7200 * t
Unnamed
rho = 200 * t
theta = 900 * t
phi = t * 90 * 10
LINKS
Peruse the links for more equations and explanations as to how they work.
Web Links
- Involute Gears
- Power Tools: Curves by Equation
- This gives details about using Pro/E dimension references in the equation to give it a parametric touch.
Links to curve-from-equation Discussions on PlanetPTC:
- Curve from Equation Sample for Newbies
- Capto
- How to Create a Curve from the Equation? Does Anybody Know?
- Datum Curve from Equation Driven by Parameters
- Constant Force Spring Model
- Involute Helical Gear Geometry
Links for related PlanetPTC content:
If you think curves from equations are cool, then the following is right up your alley. These delve into the use of variable section sweep and the trajpar variable.
- From E-learning with Vladimir Palffy
- Fun with Helical Sweeps and Trajpar
- Conch Shell in Creo Parametric
- How to Create Twisted Wires
