I know this post is pretty old to get bumped, but we are experiencing this same process in creating hose routings. We create a point file in the upper assembly using clipping points and then export this out as an iges, change the file extension and import it back in as points offset from coordinate system. Is there a way to create a program through toolkit to automate this(create a copy of a point file that uses geometry and make it offset coordinate system) or some other easier way than walking through all the steps?
The following Knowledge Base articles could also be reviewed on some topics derived from the initial post:
