I need to use the command "Stile" or "Style" in Creo 2.0 M080 to create an intersection between two surface, like here:
http://learningexchange.ptc.com/tutorial/737/using-the-style-feature-to-create-a-freeform-surface
Anyway, when i click "Style" does not apper any menu Style... Why?
Thank you.
The style feature is part of the ISDX extension, it is not included with the base Creo Parametric package. If you need style, you need to order that extension.
Thank you.
Another question: some features that now are in ISDX extension in Creo 2.0 were present in Pro-E Wf 3?
