I'm trying to edit a part created by someone else. The part is a mirrored version of an original which contains the feature tree. The newermirrored part shows no worthwhile feature tree. I can access the original part by selecting the lone mirrored feature in the newer part and "Open Base". I see and can edit the feature tree of the original part.
Is there a way to push this change through to the already mirrored part? Or would I need to created a brand new mirrored part to show this change? There is already a drawing associated with mirrored part.
Hey guys,
Thanks for checking into this. I found my problem. As mirroring an existingpart to create a new one is not a tool I have used before I didn't make sure that the dependency option was checked onthe newer part, thus the changes were not being pushed through.
Thanks again.
