Question about Sweep in two seccion
Highlighted
Newbie
Good day
I have a question, I'm trying to make an aluminum frame for a freezer but for this requir make a plastic cornerback for joining profiles.
When developing the plastic profile sweep use the tool, which makes me the piece at 90 ° but I require is to make the parts to an internal angle of 90 ° but the outside what I require a radio.
I appreciate your help
Tags (2)
10 REPLIES 10
Highlighted
Re: Question about Sweep in two seccion
I would not make this with a sweep.  I'd extrude one side, cut it at the 45 degree angle, extrude the second side through next and add the radius after with a round feature.
LinkedIn
Highlighted
Hi Doug
I understand what you say, but I can not do an external radio, since the geometry of the part will not let me, let me know if the function sweep I can do two track (1 track 90 ° internal and the second with a radio) ??
Highlighted
Surely you would be looking to do a revolved section through 90 degrees making the axis of revolution on the inner corner.
Highlighted
That depends on the design intent.  Looking at the image, it doesn't look like the outer radius is smaller than a 90 degree revolve would produce.
LinkedIn
Highlighted
Sony makes a nice "radio" if you require one.....
Highlighted
Jajaja
Ok, my mistake, I mean diameter
Highlighted
Are you looking for something like this?
The curve shown in your image has a radius to small to create this shape in one sweep s the inner surfaces would be self intersecting.  If you are looking to only radius the outer profile, two sweeps, one at a 90 and one with a radius could accomplish that.
Creo is an endless adventure: Always more to learn.
Highlighted
Hello Kevin
It is similar but the inside of the I require 90 °, if conducted in 2 parts the connection between them as I make, since it is internal and external to 90 ° it is with a radius
Highlighted
The inside portion can be made with a 90 and the outside with a radius.  The second curve needs the radius to start and end tangent to the 90 degree portion so that it is a 90 on the inside edge (similar to my previous example).
Highlighted
It can but the radius needs to be the same as the width of your profile section.
