I use CREO 2.0 and i can't save and copy of asm with family table, in the new asm i haven't the family table.
It's a confing parameter??
thanks a lot
Marco,
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS121979 tells us that:
In order to create a copy of the assembly including the family table select File > Backup: this will save a copy of the assembly with all associated objects to another directory and the copied models can then be renamed, since all objects are backed up using their original names.
Martin Hanak
