Solidworks vs proe
rohit_rajan
Solidworks vs proe
This post is solely for the love of proe
There are many things which solidworks cannot do..but which proe can do and solidworks is trying to catch with every release...
We cannot sweep on both sides of the guide curve in solidworks....if the section is in the middle..
This feature will be added in solidworks 2016
What we proe users take for granted..is not available in solidworks...
9 REPLIES 9
Try this in S/W:
Here are a few I've found:
  • Change a round feature from constant to variable and back.  In SW, once created, a round type cannot be changed.
  • Change a feature from a solid to a surface, a cut to a protrusion or from solid to thin at any time.  In SW these are all separate functions and the only option is to delete and recreate.
  • Copy a surface. In SW you must offset at a zero distance.
  • Change a draft from a curve based hinge to a planar hinge.  In SW once created, the hinge type cannot be changed.
  • Use insert mode in assy.  Not possible as of SW 2014 that I can tell.
LinkedIn
Patriot_1776
(To:dgschaefer)
Is there a "restructure" command at the assy level in SW?
You can restructure through drag and drop.
LinkedIn
Patriot_1776
(To:dgschaefer)
Moving a part from the top assembly (constrained/in BOM) to a lower-level assy and vice-versa?
I'm not sure, I haven't played with it that much.
LinkedIn
Patriot_1776
(To:dgschaefer)
That's what I mean by "restructure".  Not simply moving a part around WITHIN an assembly in the model tree (reorder).
Sorry, yes, I was able to move it from a sub-assy to the top level.I didn't simply re-order.
I didn't investigate what that might mean for assy mates nor did I try many combinations, I simply dragged a part out of one assy into another.
LinkedIn
Patriot_1776
(To:dgschaefer)
Thanks!  I remember when they added that command.  VERY handy!
