Tutorial: Sheet Metal Conversion - two examples
In this tutorial, you can learn How to use Sheet Metal Conversion modelling technique in ProE or with same logic in Creo Parametric.
This video was created based on question from a comment under my video on YouTube channel. Fell free to contact me or leave a comment, or idea for another Creo tutorial.
Vladimir Palffy - www.4kside.com
Tags: #proe #creo #creotutorial #tutorial #4kside #palffy #vpalffy #vladimirpalffy
Best Regards,
Vladimir Palffy
12 REPLIES 12
Re: Tutorial: Sheet Metal Conversion - two examples
Hi @VladimirPalffy
 the second method is absolutly fantastic. All in one feater... it´s around 6-8 features less than l would use.
Applaud for you...
Thanks for great tip
Good stuff, thanks for sharing it.
A method I've used that's similar to the second is to shell the solid before the conversion.  If you shell to the length of the return flanges you want, you can get consistent flange length on a more complex part where a simple extrude won't give you what you want.
Doug Schaefer | Engineering Manager
Crow Works
@VladimirPalffy @dgschaefer
I have a challenge for you guys :-)
We use the "start with solid, then convert to sheetmetal" method a lot, but this part in particular is giving me headaches.
Please see the picture below. The edge the red arrow is pointing to is now defined as an Edge Rip, but I want to have a Bend at that edge. But Creo keeps throwing an error when I want to change that edge to a bend.
In my mind, it should be possible...can't get it to work.
Any ideas?
Hi, thanks for your example.
This week I am out off office, but next week I will create it Smiley Wink
Best regards Vladimir
Best Regards,
Vladimir Palffy
Thanks in advance, I'm looking forward seeing your solution :-)
P.s. The part posted is from PRO/E Wildfire 4, but we also have Creo 4.0
I don't have time to play with it today, but here's a quick suggestion. Add a round to the solid to the edge that you want the bend and apply the edge rip to the seams above it.. Not the most elegant, but I find that sheetmetal doesn't often respond well to elegant solutions.
Frankly, my experience with sheet metal is trying several variations of things that I'm pretty sure should work but don't, not knowing why and coming up with a reasonable and useful workaround like this one to keep things moving along.
Crow Works
Been there :-)
I have tried to add rounds (inner and outer) to that edge, but I still can't get the conversion to work :-(
I have tried it - and seems that it easy - try to check the video
Note: in reality The Flange features is necessary to add - because at the bottom of your original shape is necessary to create Surface RIP >> the Flange feature remove this surface automatically
Good Luck with SMT conversion Smiley Happy
Best Regards,
Vladimir Palffy
Thanks @VladimirPalffy!
It seems like having all the flanges in the conversion is a bit too much for Creo.
Without those flanges, Creo 4 can make the conversion, but PRO/E Wildfire 4.0 still fails.
So it seems like Creo 4 does have some improvements in sheetmetal.
B.t.w, it's possible to create the other flanges in one flange feature, see attached picture:
