Welding Symbol Library
machinist
1-Newbie
how do you insert (welding notes, symbols) on detailed drawings. can someone tlel me where i can find the such callouts.
3 REPLIES 3
insert - drawing symbol - custom then browse to ur weld symbol library. if u dont know where ur library is, then u can do a search for *.sym and that should find all the symbols in ur hard drive or do it on the drive where all the PTC files are put in at ur company. good luck
Thanks Carlos, but after doing a search for .*sym extention files I came up empty handed. Must be a seperate package? Does anyone have welding symbols to share perhaps?
Landon *.sym, not .*sym Usually the standard PTC symbols are installed on each computer. Try insert symbol and select system symbols. Regards Eric
