import
import
Hello people.
I'm having a problem with import file, the system part to be done in another modeling program at the time of importation to be with superfice open. I wonder if there is any command that can identify the open superfice that we can not see.
Thank you .......
Re: import
What type is the imported file?
Re: import
stp, iges.
at the time that it has some faces that come open not just that some of it does not have to see any command that can identify faces open, because when we asked not to solidify in the opição to solidify.
Thank you .........
Re: import
Sometimes the open edges of a quilt are too small to readily see.
Use the search function to find these edges:
CTRL+F activates the search tool
In the search dialog, look for "EDGE" by "EDGE" with the type "ONE-SIDED"
Then hit the "find now" button.
This will highlight every open edge in the quilt.
Re: import
Thank you very much, yet did not do the procedure more so you have another import model I'll do some testing.
grateful ........
