I have an old part that has a mirror merge feature in it.
Is there a way that I can find the original part that this mirror merge came from?
Thanks in advance,
Herb Spaulding
Miller Industries Towing Equipment, Inc.
You can try looking at the Reference Viewer. But if the original part is not "accessible", it may just show you "Missing Ref".
Also look at "Investigate, File History" for a clue.
Right click on the mirror merge and select info. If I remember right, there is a comments right at tope that tells you the base part.
