Coordinate system in a drawing
  • November 19, 2015
  • 7820 views
How do I add a coordinate system in a drawing? I have an assembly where the common coordinate system is far from the small area that I'm detailing on one sheet. I'd like to add a coordinate system next to the drawing such that it is easy to understand its location. Do I have to draw it by hand or it there a better way?
Best answer by MartinHanak
Erik,
Hint no.1:
Create additional coordinate system closer to your model and use layers to hide unwanted coordinate systems.
Hint no.2:
Simulate coordinate system using datum curves.
MH
Erik,
please attach a picture of the drawing.
FYI: You can display model csys in the drawing.
MH
I can't attach a picture of the real drawing but here is a simplified drawing, I hope that it does not complicate things. If I use the Ccys display filter I'll see all the coordinate systems (several hundreds) due to the complex assembly. I only want to see the main reference coordinate system and see it in the drawing which is scaled so that I can see the subassembly.
Erik,
Hint no.1:
Hint no.2:
MH
