what is mirrored merge?
gkrishna
2-Guest
in a part file there is this mirrored merge feature,normal mirror feature doesn't work. why is that normal mirror feature won't work?
and how and when to use mirror merge?
It is the xtop version of merge.
Model tab - Operations>Feature Operations>copy>mirror>All Feat>dependent/independent...
7 REPLIES 7
I've only seen the mirror merge feature when a part has been save-as a mirrored part. It can be dependent or not. It looks like yours is not dependent. It seems to internally group all the feaures and mirrors it.
yes in the beginning of feature tree in new part file,i am confused how is this done in the middle and base part is that part itself.
and normal mirror doesn't work.
Yes, I am looking at it now. As it is, the part is merged with itself. But that option is not available in Get Data so someone played a trick. I'd like to know what that trick is too.
oh yes in wilfire its under Edit menu>Feature Operations>copy>mirror>All Feat>dependent/independent.
thank you so much.
Anytime
I have similar type of question, How to edit Mirrored Merge Feature, I can't seem to get the insert tool to stay where I want it.
Please suggest me best solution for the same
