Can someone provide the url that Windchill is connecting to for WPA data transmission to PTC? Our firewall guys want a specific outgoing address that is required for successful WPA data transfer, instead of having a wide open 443 rule on our Windchill servers.
You can read this article for Creo, but it is the same configuration.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS72479
Based on the response from Marco, you can see that the specific URL is https://apps.ptc.com. If this is the correct response required by your IT team, please be sure the mark the answer correct to aid future community visitors.
Thanks for posting!
- Dan
