Hello
I am curious to know why there is no specific section for ECAD in this forum ? Does that mean that Creo is not used for ECAD and schemantic designs ?
I am trying to find out if Creo fully support IEC81346
I have found this thread below which is now closed and it would appear that in the past this was not the case.
However, I could not find any update nor could I find a datasheet telling me which IEC standard Creo supports.
Thank you in anticipation for any clue 🙂
ECAD is in the Routed Systems under Creo Parametric
https://community.ptc.com/t5/Routed-Systems/bd-p/routedsystems
