Units and NHA in Title block
Sanjay
2-Explorer
Hello Forum,
What is the system parameter for unit that has been used in the model/drawing?
I want to use it for title block so when ever a model is introduced to the sheet, the sheet shall update the units of the dimensions.
Also the same parameter for NHA for title block
Thanks in advance,
Sanjay
KenFarley
(To:Sanjay)
If you did a quick search for what you're asking, you might have found the following:
Old Question about Units Parameter
which seems to indicate that there is not a units parameter associated with a model that can be queried or otherwise used for relations or drawings. A pity, but not surprising. Pretty much every company I've ever done drawings for dictates the units must be in one particular system, be it metric or english.
