We have multiple versions of cross sheet graphics and sometimes a wrong one has been placed. Is it possible to change one that has been placed without removing the connection and starting over?
Bill,
Select port (you can use port selection) and on the Diagramming tab under Replace Shape the pull down has Replace Port Shape.
Bill,
