Problem with installation
MCS
Hello, I received the following error at the end of the Installation process of Vuforia Studio:
twx-studio:index uncaughtException Error: listen EACCES 127.0.0.1:3000
Can you help me?
Best regards,
Martin
tmccombie
(To:MCS)
Hi Martin,
Studio utilizes port 3000 to run on your machine. It looks like there is an issue with connecting to that port. Can you confirm that no other applications that you are running are using this port? Please also ensure you do not have multiple instances of Studio running at the same time.
Hi.
I am experiencing the same issue: SyntaxEditor Code Snippet
uncaughtException { Error: listen EACCES 127.0.0.1:3000
and I am unable to get access to the application.
I am not sure how to change the port number.
I saw the other posts on the matter and I was not successful in solving the issue.
Attached error screen also shown. I can not click "Open".
dupatel
(To:kk2)
@kk2 Regarding the query to change default Studio application port (3000):
You can ADD & set the environment variable "PORT" to the port of your choice, on Windows this will be the Environment Variables under the System Properties.  Looks like the "Open" button from the Studio launcher will not open the proper URL when you do that so you will need to manually open the URL in Chrome with the new port: http://localhost:<diff_port>/home
-Durgesh
kk2
2-Guest
2-Guest
(To:dupatel)
I'm in.
Thanks.
Had to uninstall, restart and reinstall as well. Not sure why.
