I can not check on Project "ThingWorx Studio" published project on "smartphone (Android)" "ThingWorx View".
In "ThingWorx View" you can only check what is in by default.
How can I check published projects on smartphone's "ThingWorx View"?
(I am using "ThingWorx Studio 90 day trial")
Hi Go. Using the ThingWorx View app on your mobile device, you can scan the ThingMark you have associated with your published experience. You will want to use the 'scan' mode of ThingWorx View to achieve this.
