Show face parts in AR Experience
pjahn
Is there any change to have face parts (non-solids) from a pvz file shown in ThingWorx Studio? Customers have imported geometry from foreign sources and are not able to modify it.
Thanks for your suggestions.
pjahn
(To:dupatel)
@dupatel
The face parts are contained in the pvz file and can be shown in creo view with filters. Storing the pvz file with altered options in Creo Parametric solves the problem and the face parts are visible in ThingWorx Studio:
From Parameter > Miscellaneous tab disable the Quilts as Construction Geometry**
or in the rcp-file:
adapter/convQuiltAsDatum=0
dupatel
(To:pjahn)
@pjahn Could you please clarify customer imported geometry and not able to modify it. Do you want to make changes to the PVZ inside ThingWorx Studio ? or The requirement is to show only face parts available on a PVZ file inside studio?
-Durgesh
pjahn
(To:dupatel)
@dupatel
or in the rcp-file:
