Hi
I realized that the pvz file from Creo Illustrate can only transfer the animation. Seems that with transferring the following items, it will be a great way to work.
So, can I check is there anyway to transfer:
- Multiple steps
- Annotations
- Symbols
- Insets
- Exploded lines
- Finally same orientation of animation as in the Illustrate (as we capture camera position)
- Ravi
All of the steps in a sequence will transfer and you can play them all sequentially or step thru them one at a time.
But I think everything else on your list does not transfer. I have tried with symbols and they do not transfer as far as I can tell. But maybe someone else knows for sure if these transfer.
Thank you.
- Ravi
