Hi PTC
I recently acquired a new work PC and I had to re-install Creo Elements 8.0 (free version)
On my old PC I did not have to use the Manual Activation, it would just load up straight away but for some reason that is no longer the case!
Now it does not find internet connection and when I then use the Manual Activation Key I get the following error message;
“The activation check for Modeling Express
to run on this machine failed because of the
following reason:
The activation code you entered is invalid.”
Can you please help as I regularly use this software?
Hallo,
the same problem by me for some weeks.
I'm using Win7/Creo Elements 6.0 (free version)
But fortunately it's working again since today morning.
