Animation Application to create animations
klakshmi
6-Contributor
I am using Creo Parametric Release 4.0 and DatecodeM150
I am using the Animation Application to create animations and videos of
an assembly in motion using snapshots. I can generate animations using
snapshots until I create gear connections in the mechanism application
(there are gear to gear connections and worm gear connections). I can
drag the components around with some lag, but when I try to generate an
animation those components affected by the gear connections do not move.
Here are the errors that I faced
N/A
0 REPLIES 0
