I am using Creo Parametric - Release 2.0 (connected) 2.0 M150
HI, Could you give us best practices for configuration of the nvidia control panel. Our computers are running parametric 2.0 M250 and 5.0.6.0 and simulate Our graphic cards are Quadro RTX 4000 (on Dell Precision 3640 Tower) Thanks a lot. François
Anybody to reply ?
The only thing I remember changing on the nvidia control panel was to make sure there was no video scaling which caused mouse pick errors.
Thank you Steve, I'm going to ensure there is no scaling. I let you know the results...
Hi Steve, nothing changed after disabling videoscaling.
Rotation seems to be fluent but zooming is more complicated.
There's a lag between the move of the wheel and the move made in Creo Parametric (1-2 sec)
What specific issues are you trying to fix (prior to the scaling change)?
