We’re aware of an issue preventing community login. Our team is actively working on a fix and we’ll share updates as soon as possible.
Compatibility of Pro E 5 with Windows 8.1
mpapreja
Is pro e 5 compatible with windows 8.1? Clicking on setup file does not show up anything!!
Manish Papreja
Manish,
Wildfire 5.0 is not supported on Windows 8.1, Creo 2.0 M100 and later are supported on Windows 8.1. For Wildfire 5.0 try executing setup.exe using > Right Click > Run an admin, not sure it will start installation or not, however you can make a trial.
Manish,
you can copy Wildfire 5.0 installation from another PC to Windows 8.1 PC and test if it runs.
Martin Hanak
Martin Hanák
Dear Martin,
Thanks for the suggestion. Should be a good solution if it works but I don't know how to copy installation from one pc to another. I have another PC having Windows 7 32 bit where wildifire 5. is working fine and my target PC is having windows 8.1 64 bit. Could u please guide me in trying the suggested option?
Manish
Manish,
Dear Martin,
Manish
How to ProE WF5 installation from W7 to W8.1:
  1. W7 - let's assume that ProE WF5 installation directory is C:\PTC\proeWildfire5
  2. W8.1 - copy C:\PTC\proeWildfire5 directory from W7 to get C:\PTC\proeWildfire5 in W8.1
  3. W8.1 - modify parametric.psf in ProE WF5 installation bin subdirectory - replace %PRO_MACHINE_TYPE% with i486_nt
  4. run proe.exe from ProE WF5 installation bin subdirectory
Martin Hanak
Martin Hanák
