Config Option Setting file location for Prodetail.dtl
amorales
Hi Creo Admin Community,
I have been setting up my companies Config.pro and .sup options.  The question specifically I have is the drawing_setup_file option which sets the location of the prodetail.dtl file for drawings.
When starting a new drawing it doesn't seem to follow the path I set with the company set options (example of what I have in config.pro drawing_setup_file C:\Home\creo\Configuration\prodetail.dtl).  I even put the file in the <creo3.0_loadpoint>\text\prodetail.dtl and the options are still not how I set it.
Only when I point to the prodetail.dtl by way of File>Prepare>Drawing Properties>Detail Options (change) does my options are set for my session.  And of course closing and opening Creo 3 my prodetail.dtl options are back to OOTB
1) How to set the prodetail.dtl location so that it has my option setting without going thru the detail options change?
2) Where is the standard drawing options set if not in the <creo3.0_loadpoint>\text\prodetail.dtl.  It seems to be pulling somewhere else for active drawing mode.
Thank you.
Anthony
Another thing to note, if you are using drawing templates, none of those settings apply.
A drawing template is treated the same as an actual drawing file by Creo.  For existing drawings (and templates), dtl settings are applied and saved within the drawing file and the dtl file is not re-applied whenever it is opened.  You'll need to re-apply your dtl settings to the templates when ever you make a change.
LinkedIn
I have these three setting in my config.pro
pro_dtl_setup_dir <file path>
drawing_setup_file <file path>\inch_asme.dtl
format_setup_file <file path>\inch_asme.dtl
...and of course, make sure your files are there.
Ron
Thank you very much with the information I should have looked a little more closely to the Config options.
LinkedIn
Thank you Doug.  Much appreciated
