Creating a PDF with different page sizes
TM_10264935
1-Newbie
I am using Creo Parametric Release 8.0 and Datecode8.0.4.0
I would like to create a PDF which contains a drawing in format 8-1/2 by 11 (A) and a format 11 by 17 (B), in the same drawing.
example: page 1 is of format A and page 2 is of format B.
Except that, when printing if the format A page is first, the second page which is format B will be compressed into format A.
So, is it possible to create a PDF document and have the first page come out in format A and the second page come out in format B.
2 REPLIES 2
TomU
(To:TM_10264935)
Yes.  Fitting all pages of a PDF to a certain paper size is controlled by the print output settings of the PDF viewer.  It has nothing to do with Creo.
Hi @TM_10264935 ,
It appears that the information shared by @TomU  answers your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Mahesh
