Creo 2.0 Planar Axis Flipping Issue
jkilhoffer-2
Software: Creo 2.0, Date Code M220
A colleague is experiencing an issue in which an axis created by a hole in the original planar wall flips direction after making an edit to a part and regenerating. I am fairly certain the axis from the original planar wall is the culprit, as the issue goes away when I create a datum axis and reference it instead of the axis from the original planar wall.
Below is the procedure used to reference the axis. This has been a standard procedure for years, and only now has this issue popped up. Is there a bug in the date code we're using and (if so) is there a fix coming?
I've attached the part for reference.
In sheetmetal, the sketch for the first planar wall has a circle in it that creates a hole after extrusion.
A hole (from Creo tool) was then created that references the axis made from the extruded hole of the original planar wall and the x-plane.
If an edit is made to the original planar wall (not "edit definition"), the hole and its reference appear to mirror across the plane perpendicular to the x-plane.
The hole remains in this incorrect position until the following procedure is executed on the original planar wall:
  • "Edit Definition"
  • References
  • Edit
  • OK
  • OK
If I change the referenced axis to a datum axis or one that I create by extruding a geometric point, the issue goes away.
Background:
This same method has been used on several parts in the exact same way and has only become an issue now. We are using Creo 2, Date Code M220.
I've had flipping problems because of negative values in directions.
Nothing I could follow logically; it held the - (minus) and simply kept flipping on each regen.
I suspect it was a bug that was fixed long ago since I am still on M040.
This was an isolated case that only comes up every once in a while.
Redefining the feature with different references normally fixes it.
