Creo Parametric Options: Entity Display
Srinivasan-Iyer
Hi
I am on Creo 10.0.9.0
As detailed in the picture below, as I increase the value of the Transparency, opacity increases. Shouldn't it be named to Fill Opacity instead of Fill Transparency?
Hope I am not missing anything.
Regards
Srinivasan Iyer
8 REPLIES 8
No, that's not how setting a transparency typically works. Transparency, in programming and in programs that provide this setting for appearances, always is defined as "the lower the number, the more transparent". Should it be called opacity? Maybe, but that's just not the way it's been historically done.
Historically .... May be someone started it incorrectly. However, logically when we say something is 100% Transparent, it is 0% opaque. or when we say something is '0% transparent' or 'not transparent at all' then it is '100% Opaque'.
Anyone...?🙂
Regards
Srinivasan Iyer
Yes, I know. Other programs, like GIMP express this correctly, referring to Opacity, etc.
Oddly, if you change model appearances, via Appearances->Edit Model Appearances,  the "Transparency" setting behaves as you'd expect (0% totally opaque, 100% totally invisible).
Thanks for the reply @KenFarley
Regards
Srinivasan Iyer
Hi @Srinivasan-Iyer,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
Hi @Catalina ,
Appreciate your reply.
There is still no solution to the issue. In my opinion it is an Anomaly to be addressed by PTC.
Regards
Srinivasan Iyer
You can open a PTC support case here, if needed.
Best regards,
Catalina
PTC
Regards
Srinivasan Iyer
