Yes, Pro/E has done that forever. It makes no difference what kind of object you open in the first window. If you notice, there will be a message pop up telling you that you cannot close the first window. If you open another object it will come up in the first window.
In Reply to David Haigh:
I just noticed that Creo leaves an empty window open. This is Creo 2-m090. I wonder if other rev's behave like this?
1. Started up Creo.
2. I opened a drawing.
3. From the model tree, selected the top assembly in the drawing and picked open.
4. I switched back to the drawing and closed that window.
5. The screen switches back to the assembly.
But I noticed in the system tray that there are two windows open.
[cid:image001.png@01CF48CA.82114FC0]
When you hover over it so you see the files names, you see this:
[cid:image002.png@01CF48CA.82114FC0]
The "Creo Parametric" pick is an empty window. You can't close it.
The pull down inside of Creo show only one window choice.
[cid:image003.png@01CF48CA.82114FC0]
If I pick a sub-assy from the model tree, and pick open it opens it in the blank window.
I know that because I don't get a third window shown in the system tray, and it now shows this when I hover over it:
[cid:image004.png@01CF48CA.82114FC0]
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
PTC quality philosophy: We've upped our quality standards. Up yours.
