Hi, the server for using direkt modeling express is down therefore i cannot copy an activation key, can you help please?
Best Andre
Hi Andre, have a look here: https://community.ptc.com/t5/System-Administration/Lizenz-Server-down/td-p/1039066
Which PE version you do have installed?
and then see the list of already existing topics for the same issue here.. There is also mentioned how the problem was solved for several people during the last couple of weeks.
BTW: it would be great first to search in an online forum / community before opening a new thread to same topic again and again . Thank you.
Hi @AM_10525402
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
