I am having a problem with the Quadro 2000 (Windows 7 64 bit on a Dell T7500). When I first open up a model then the screen is black until I rotate it. Also sometime the buttons are greyed out for some menu picks. However, it is my own fault as it is not listed as supported:
http://www.ptc.com/WCMS/files/60077/en/dell_wf4.pdf
In Reply to Paul Korenkiewicz:
http://www.nvidia.com/page/quadrofx_family.html
Nvidia Quadro's... They list midrange as the 2000 model...
Thanks...
Paul Korenkiewicz
FEV, Inc.
4554 Glenmeade
Auburn Hills, MI., 48326
I've got a Dell T3500 with Win7 Ultimate and Quadro 2000. I had no problems at first, then I added a second monitor. After that I started getting Pro/E black screens, also had problems with dialog boxes for family table instances and simplified reps not showing up. I poked around and found the nView had been turned on during the second monitor configuration. I turned nView off and everything is working fine once again. I've had problems on previous computers with nView affecting Pro/E so I strongly recommend you turn it off.
