How do you import a table in the Function Definition dialog box within Mechanica or the Simulate module?
ddallesandro
In my simulation, I'm trying to import a table in the Function Definition dialog box. What file types/formats are supported? I've tried CSV, XLS, XLSX, TXT but none of them work. The only error message I receive is "Error reading the file."
Hi Drew
A .txt file, made in notepad should do the trick
use a space or a tab between the x and y values as in the attached example
Good luck
Erik
Hi Drew
Good luck
Erik
Thank you so much!
