How to get Windchill Part Name and Part Number in Creo Model?
On an assembly drawing I have to show a list of its components. But I need specify names and numbers
of the Windchill's parts which the models linked to as OWNER.
Windchill adds some parameters to CAD model during upload. So I can see parameters like PTC_WM_CREATED_ON, PTC_WM_REVISION, and so on.
I have found these parameters in Windchill 10 > Site/Organization Preference Management > Mapping System Attributes and File Properties
I can see some extra parameters in the same list which may meet my needs: PTC_WM_PART_NAME, PTC_WM_PART_NUMBER (Description : Identifies the name of the property in the CAD tool that shows the CAD Document's "Owner" associated Part Number. The value may be set to a CAD System Attribute. The default value is PTC_WM_PART_NUMBER.)
The problem is that I can not find these parameters (PTC_WM_PART_NAME, PTC_WM_PART_NUMBER) in Creo model. If I try to add parameter with any of these names to Creo model I have the message that this names are reserved.
Is this bug? Or am I doing something wrong?
I am using Creo 1 M010 and Windchill 10 M020
