I had try off the show animation function as blow.
Creo prametric Options > Model Display > Show animation check off > apply > OK
But this function was turn on again.
How can I apply this option by off Show animation or save the changed options.
I using the company license.
plz help.
try adding following option into config.pro file
MAX_ANIMATION_TIME 0
Desr sir,
Thank you so much!!
