I am setting upPRO/INTRALINK 3.4 m062 and WF3 and I am doing something, or missing something although I have done this dozens of times.
I get INTRALINK to launch just fine.
I get PRO/E to launch just fine.
However, when I launch PRO/E from w/in a Workspace, I get a Authorization dialog/log-in, that I have never seen before. See attached.
And even if I were to enter a username (which I never had to before) it is not reconzed.
Eventually I get a secon dialog, see attached (capture2.png), stating that the Pro/INTRALINK process is not found.
I do have the system variable set for PDM_LDB_PATCH set, and in addition I have the CONFIG setting dm_remember_server no, for launching PRO outside the ILINK world.
For what it is worth, I did just get license files and placed on the server, however, I do not think that is the issue because no other machine is having this issue.
In addition to that, I am installing on a Windows 7 x64, and I do have the JAVA workarounds set. Again, I do not think this is the issue either because I have other Windows 7 machine running in the same way.
Anyone have ideas what I am missing/forgetting that is causing this Authorization dialog?
