MC Config Load / Follow Up
jlippeth
Problem solved
It seems just because you rename the condition files thru the interface (edit setconf.mcc)
You still need to rename them in a file called msg_mc.txt
Thanks to K.U.
“edit msg_mc.txt file located in <modelcheck_load_point>\MC_CONFIGS\config\text\”
FYI. The help center mentions “Open the setconf.mcc file using a text editor.” And your life will be filled with riches!
Yea I followed that advise only to have awoke the inner beast within.
Thanks to this group I can remain calm and proceed along the rainbow of prosperity
JSCOTT
0 REPLIES 0
