Premature exit from drawing while creating annotations
dthornton
I am using Creo Parametric Release 7.0 and Datecode7.0.5.0
I have a user who is being exited out of the system when working on creating annotations to a 2D print. Specifically trying to add annotations such as notes. Issue started today and has happened on multiple parts.
4 REPLIES 4
Dale_Rosema
(To:dthornton)
Did any video drivers or other updates occur on the system during the night?
dthornton
(To:Dale_Rosema)
Last system update was 7/13 and didn't appear to be any video drivers updates either.
test no. 1.
Add graphics win32_gdi option at the end of config.pro and test problematic action, again.
test no. 2.
Test problematic action on different computer using the same drawing.
Martin Hanák
Hi @dthornton-2 ,
Did you manage to test the options suggested by Martin? If required you may try updating Creo to latest available build of Creo 7.0.
Thanks.
