ProE Wildfire 3 & Windows 7
ptc-1775039
Is there a possibility to work with Wildfire 3 on a Windows 7 system? Installation is no problem, I tried, but when working with it, the program is very slowly and lacks a lot! On my old Windows XP system it worked perfectly! Thanks for help!
Check graphics driver, download it from the vendor. There was another post about this and it solved the problem.
Yes I have the same issue on my windows7 notebook. It gets a bad performance when I do something in sketch. The drawing area is flickering. I have tried many versions of graphics drivers, including vista version and latest version for win7 from gfx vendor site. But it does not work! There is not any problem on a XP system. Windows 7 32bits Notebook cpu-T6600 gfx card-Geforce GT 130M
Same problem will occurs in wildfire 4 also >please install or upgrade your internal Graphic Card (integrated card to 512MB or 1GB). upgrade and reply me, it will work or not..
