Hello everybody,
our IT department would like to deploy several machines with ProEngineer and ProIntralink. Unfortunately those two provided switches are not satisfying. Talking about setup.exe -uilog and setup.exe -uitrail <install-unattended.txt>.
What did I do?
Our issue is that there is that the ProE installation with the trail-file doesn't work completely because the Java Runtime Environment is not captured in the whole uilog-Capture-process. So I deactivated the module but sometime the installation still just stops at within the setup.
I'd be glad to get some help because the users should get and test the new Windows 7 x64 with ProE and ProI soon.
Bye
