Problem in CREO M080 silent installation in Windows 7 32 bit system
ptc-5407431
E:\setup.exe –xml “D:\temp\ptc\pma.p.xml” —xml “D:\temp\ptc\creobase.p.xml”
Running the above command in command shell I am able to install Creo in 64 bit Windows 7 environment .
But Croe does not get installed in 32bit Windows 7 when the same command is run in with the xml files changed (the .xml files taken from 32 bit installation )
0 REPLIES 0
