I am using m050 and it is fixed here!
But maybe loading a config.win created in previous versions still doesn't work, try creating a new config.win using your current version.
Its possible that there are some specific customizations that config.win can't handle anymore tough...
Warm Regards
Guilherme Rocha - Tech Support Consultant
PLM Solutions do Brasil
“A goal without a plan is just a wish.”
The customizations I use are minimal, so probably I am not getting into the "BUG", I advice you to contact PTC and ask for a WEBEX session which they can remotelly access your computer and gatter more data to find the solution.
Warm Regards
Darrin,
Are you using a .bat file to load your config options?
I had similar issues when I was setting up our config.win when we moved from WF3 to WF5. I think my problems had more to do with the fact that we moved to Windows 7 than the Pro/E upgrade. I ended up having multiple config.win files that Pro/E was loading and they were screwingeach otherup. I have a.bat file that loads Pro,and I had to update itto delete all the config.win files (things were stored in different locations than what I have on myXP machine)and pull the latest from the network. Noweverything works fine. I also had to change folder permissions on locations that had config options stored in them so that my .bat file could modify/delete/write files in that folder (Win7 nuance). Pro looks in several locations for config.win files and will load multiples if it finds them.
Then again, our config.win file isn't all that complicated. A few custom mapkeys icons and such, so maybe that has something to do with it...
-Roger
In Reply to Darrin Hiebert:
Guilherme (and others suggesting it's been fixed):
Well, unfortunately, it IS NOT fixed in M020, M030, or M040. I have had users tell me that all of these versions are doing the same thing.
Now, it's possible that PTC fixed "something", but the problem that I'm experiencing (and it sounds like others are as well ), is not fixed as late as M040...
