SPECapc PTC Creo 3.0 benchmark run fail
tjacky
I got a problem when I run the SPECapc PTC Creo 3.0 benchmark on creo 3 with fully license, the error message said " Installed graphics supports a minimum of 8x MSAA so compare results only to 8x MSAA results". Did anybody had this issue? Many Thanks.
@echo OFF
REM SPECapc PTC Creo 3.0 benchmark
REM
REM Parameter 1 : (optional) Pro/E command -- the command to start Pro/ENGINEER
REM (default is "C:\Program Files\PTC\Creo 3.0\U490\Parametric\bin\parametric.exe")
REM Parameter 2 : (optional) if set to "batch" the notepad output will be disabled to allow for multiple simultaneous runs
REM
REM Contents ?Copyright 2014, Standard Performance Evaluation Corporation
REM
REM Edit the definition of BASE_DIR to indicate the path to the  top-level directory of
REM the tree  of benchmark files.
SET BASE_DIR=..
SET TRAIL_DIR=%BASE_DIR%\benchmark\apc_trails
SET BENCH_DIR=%BASE_DIR%\benchmark
SET SCORE_DIR=%BASE_DIR%\results
SET UTILITIES_DIR=%BASE_DIR%\utilities
SET CONFIG_DIR=%BASE_DIR%\config
SET SCRIPT_DIR=%BASE_DIR%\trail
SET PROECMD="C:\Program Files\PTC\Creo 3.0\M010\Parametric\bin\parametric.exe"
SET PRO_MACHINE_TYPE=i486_nt
SET TRAIL="All_V25.txt"
SET CHECK=FALSE
SET BAT=FALSE
REM Copy config and trail file into benchmark directory
IF EXIST %CONFIG_DIR%\config.pro COPY /Y %CONFIG_DIR%\config.pro %BENCH_DIR%\
IF EXIST %CONFIG_DIR%\config.win.32 COPY /Y %CONFIG_DIR%\config.win.32 %BENCH_DIR%\
REM see if any parameter is "batch"
IF "%1"=="batch" SET BAT=TRUE
IF "%1"=="BATCH" SET BAT=TRUE
IF "%2"=="batch" SET BAT=TRUE
IF "%2"=="BATCH" SET BAT=TRUE
REM set the ProE Command
IF "%BAT%"=="TRUE" goto skipcmd
IF NOT "%1"=="" SET PROECMD=%1
:skipcmd
REM Create Directory to hold trail files
IF NOT EXIST %TRAIL_DIR% mkdir %TRAIL_DIR%
REM Clean up any old files
IF EXIST %TRAIL_DIR%\trail.txt.* DEL /Q %TRAIL_DIR%\trail.txt.*
IF EXIST %TRAIL_DIR%\current_session.pro DEL /Q %TRAIL_DIR%\current_session.pro
IF EXIST %BENCH_DIR%\4901000_asm__out.log.1 DEL /Q %BENCH_DIR%\4901000_asm__out.log.1
IF EXIST %BENCH_DIR%\4901000_asm.igs DEL /Q %BENCH_DIR%\4901000_asm.igs
IF EXIST %BENCH_DIR%\4903000_asm__out.log.1 DEL /Q %BENCH_DIR%\4903000_asm__out.log.1
IF EXIST %BENCH_DIR%\4903000_asm.igs DEL /Q %BENCH_DIR%\4903000_asm.igs
IF EXIST %BENCH_DIR%\01-2_crankshaft.asm.2 DEL /Q %BENCH_DIR%\01-2_crankshaft.asm.2
IF EXIST %BENCH_DIR%\crankshaft.drw.1 DEL /Q %BENCH_DIR%\crankshaft.drw.1
IF EXIST %BENCH_DIR%\01-20000.m_p DEL /Q %BENCH_DIR%\01-20000.m_p
IF EXIST %BENCH_DIR%\worldcar_shaded.tif DEL /Q %BENCH_DIR%\worldcar_shaded.tif
IF EXIST %BENCH_DIR%\worldcar_exploded.tif DEL /Q %BENCH_DIR%\worldcar_exploded.tif
IF EXIST %BENCH_DIR%\worldcar_shadedEdges.tif DEL /Q %BENCH_DIR%\worldcar_shadedEdges.tif
IF EXIST %BENCH_DIR%\worldcar_shadedReflection.tif DEL /Q %BENCH_DIR%\worldcar_shadedReflection.tif
IF EXIST %BENCH_DIR%\worldcar_wireframe.tif DEL /Q %BENCH_DIR%\worldcar_wireframe.tif
IF EXIST %BENCH_DIR%\worldcar_nohidden.tif DEL /Q %BENCH_DIR%\worldcar_nohidden.tif
IF EXIST %BENCH_DIR%\worldcar_hidden.tif DEL /Q %BENCH_DIR%\worldcar_hidden.tif
IF EXIST %BENCH_DIR%\worldcar_shaded8xAA.tif DEL /Q %BENCH_DIR%\worldcar_shaded8xAA.tif
IF EXIST %BENCH_DIR%\worldcar_shadedReflTransp.tif DEL /Q %BENCH_DIR%\worldcar_shadedReflTransp.tif
IF EXIST %TRAIL_DIR%\current_session.pro DEL /Q %TRAIL_DIR%\benchmark_Body_Appearances\current_session.pro
IF EXIST %BENCH_DIR%\benchmark_Body_Appearances\worldcar_shadedReflSSAO.tif DEL /Q %BENCH_DIR%\benchmark_Body_Appearances\worldcar_shadedReflSSAO.tif
IF EXIST %BENCH_DIR%\benchmark_Body_Appearances\worldcar_shadedReflPersp.tif DEL /Q %BENCH_DIR%\benchmark_Body_Appearances\worldcar_shadedReflPersp.tif
IF EXIST %BENCH_DIR%\Relations_to_verify.log.* DEL /Q %BENCH_DIR%\Relations_to_verify.log.*
REM Move APPDATA to ensure dialogs are always the same
IF EXIST %APPDATA%\PTC-TEMP RMDIR /S /Q %APPDATA%\PTC-TEMP
MOVE %APPDATA%\PTC %APPDATA%\PTC-TEMP
ROBOCOPY /njh /njs /ndl /nc /ns %UTILITIES_DIR%\PTC-BM %APPDATA%\PTC *.* /E > log:nul
REM Run the benchmark
PUSHD %BENCH_DIR%
call %PROECMD% 0 7 1 %TRAIL% pro_wait
POPD
REM Move APPDATA back to original settings
IF EXIST %APPDATA%\PTC RMDIR /S /Q %APPDATA%\PTC
MOVE %APPDATA%\PTC-TEMP %APPDATA%\PTC
REM Create Directory to hold results
IF NOT EXIST %SCORE_DIR% mkdir %SCORE_DIR%
REM Remove any old copies of the trail, score and results files
IF EXIST %SCORE_DIR%\score.txt DEL /Q %SCORE_DIR%\score.txt
IF EXIST %SCORE_DIR%\score-steps.txt DEL /Q %SCORE_DIR%\score-steps.txt
IF EXIST %SCORE_DIR%\score.csv DEL /Q %SCORE_DIR%\score.csv
IF EXIST %SCORE_DIR%\result.txt DEL /Q %SCORE_DIR%\result.txt
IF EXIST %SCORE_DIR%\trail.txt DEL /Q %SCORE_DIR%\trail.txt
IF EXIST %SCORE_DIR%\worldcar_shaded.tif DEL /Q %SCORE_DIR%\worldcar_shaded.tif
IF EXIST %SCORE_DIR%\worldcar_exploded.tif DEL /Q %SCORE_DIR%\worldcar_exploded.tif
IF EXIST %SCORE_DIR%\worldcar_shadedEdges.tif DEL /Q %SCORE_DIR%\worldcar_shadedEdges.tif
IF EXIST %SCORE_DIR%\worldcar_shadedReflection.tif DEL /Q %SCORE_DIR%\worldcar_shadedReflection.tif
IF EXIST %SCORE_DIR%\worldcar_wireframe.tif DEL /Q %SCORE_DIR%\worldcar_wireframe.tif
IF EXIST %SCORE_DIR%\worldcar_nohidden.tif DEL /Q %SCORE_DIR%\worldcar_nohidden.tif
IF EXIST %SCORE_DIR%\worldcar_hidden.tif DEL /Q %SCORE_DIR%\worldcar_hidden.tif
IF EXIST %SCORE_DIR%\worldcar_shaded8xAA.tif DEL /Q %SCORE_DIR%\worldcar_shaded8xAA.tif
IF EXIST %SCORE_DIR%\worldcar_shadedReflTransp.tif DEL /Q %SCORE_DIR%\worldcar_shadedReflTransp.tif
IF EXIST %SCORE_DIR%\worldcar_shadedReflSSAO.tif DEL /Q %SCORE_DIR%\worldcar_shadedReflSSAO.tif
IF EXIST %SCORE_DIR%\worldcar_shadedReflPersp.tif DEL /Q %SCORE_DIR%\worldcar_shadedReflPersp.tif
REM Calculate Score
COPY /Y %TRAIL_DIR%\trail.txt.1 %SCORE_DIR%\trail.txt
COPY /Y %UTILITIES_DIR%\apc.dat %SCORE_DIR%\apc.dat
%UTILITIES_DIR%\%PRO_MACHINE_TYPE%\ProEscore.exe -useconfig -checkaa %SCORE_DIR%\trail.txt >> %SCORE_DIR%\score.txt
%UTILITIES_DIR%\%PRO_MACHINE_TYPE%\ProEscore.exe -steps -noconfig %SCORE_DIR%\trail.txt >> %SCORE_DIR%\score-steps.txt
MOVE score.csv %SCORE_DIR%\score.csv
MOVE result.txt %SCORE_DIR%\result.txt
MOVE %BENCH_DIR%\worldcar_shaded.tif %SCORE_DIR%\worldcar_shaded.tif
MOVE %BENCH_DIR%\worldcar_exploded.tif %SCORE_DIR%\worldcar_exploded.tif
MOVE %BENCH_DIR%\worldcar_shadedEdges.tif %SCORE_DIR%\worldcar_shadedEdges.tif
MOVE %BENCH_DIR%\worldcar_shadedReflection.tif %SCORE_DIR%\worldcar_shadedReflection.tif
MOVE %BENCH_DIR%\worldcar_wireframe.tif %SCORE_DIR%\worldcar_wireframe.tif
MOVE %BENCH_DIR%\worldcar_nohidden.tif %SCORE_DIR%\worldcar_nohidden.tif
MOVE %BENCH_DIR%\worldcar_hidden.tif %SCORE_DIR%\worldcar_hidden.tif
MOVE %BENCH_DIR%\worldcar_shaded8xAA.tif %SCORE_DIR%\worldcar_shaded8xAA.tif
MOVE %BENCH_DIR%\worldcar_shadedReflTransp.tif %SCORE_DIR%\worldcar_shadedReflTransp.tif
MOVE %BENCH_DIR%\benchmark_Body_Appearances\worldcar_shadedReflSSAO.tif   %SCORE_DIR%\worldcar_shadedReflSSAO.tif
MOVE %BENCH_DIR%\benchmark_Body_Appearances\worldcar_shadedReflPersp.tif  %SCORE_DIR%\worldcar_shadedReflPersp.tif
IF %BAT%==TRUE GOTO end
CALL notepad %SCORE_DIR%\score.txt
:end
0 REPLIES 0
